I just got my WD Live TV - I have it all connected to my TV already… now here is where the problem lies…
I’m running on a mac 10.6.2…
Have my computer wireless connected to my airport express. My question is - how can I set up my computer/WD live tv to stream wirelessly thru Network shares?
The WD unit says unable to detect any network connection. Do I need to get a USB wireless adapter for it work? Can the WD recognize my network setup thru just the airport? Do I manually need to configure the WD - with my ip, dns, etc…
I cant run a cable to the unit (its not possible since my computer is in a different room away from the unit) … but i cant get it to work wirelessly so im stuck… please help!
The WD will automatically setup the network, go onto the internet and report firmware update available.
I’m not fimiliar with the airport express but a review states “The Express’s USB port is also less functional than its larger sibling’s: although it lets you share a USB printer across your network, it doesn’t support sharing a hard drive, as you can with the Extreme’s AirDisk feature,” which probably means a usb hd plugged into the express. HDs on the pc should be able to be shared.
