I have an N900 with a Toshiba Canvio Basics 3.0 1TB drive connected to the USB and the drive is unusable!
I can see the drive in Windows Explorer and everywhere else.
But, when I try to copy files using backup software or Windows Explorer, it does some files then the connection to the USB drive is lost and the process aborts. Shortly the drive will be visible again and it stays that way until I try and copy files, then it goes away again.
I bought this router and I bought this USB drive to use as a backup system for my PCs for disaster recovery.
Now I’m stuck and pretty peeved.
Help Mr. Wizard!
