I’ve had a mynet 900c for about a year now and have had no problems up til now. I have only used it as of late as a wireless shared storage at home, not hooked up to the internet. Recently in moving furniture I disconnected power to the device and upon reconnecting power I found that while my two computers could reconnect to the device, the shared storage was no longer available. I’ve got a bit less than a TB on the storage before this happened.
The device does not appear to have been reset- the admin password for the dashboard remains unchanged.
I was able to connect my external hd via usb to the device, map the network drive, and access files off the external hd. Both my computers access the router by either ethernet or wireless without a problem.
In WD quickview when I hover over the task bar icon it says “MyNet900c” under drive name, “N/A” under Used, and “OK” under temperature.
In WD smartware the program says that the device has “No writable WD Smartware partition found” I can’t seem to figure out what happened to the storage.
Any help would be appreciated.
