Hello to the Community,
First post as I´m going crazy with this issue.
4 weeks ago I could not longer browse my files. I can map the drives, see folders at root but it takes 60 seconds average to get into a sub-folder. No way to read files.
Device status: led is blue, I can ping the device, connection to internet. As usual since I bought it 3 yeards ago.
Using WD My Cloud? It can´t connect, “sit back while …” message for hours.
Browser access local WLAN? after minutes it starts downloading firmware version, list of drives, etc…
WD Web Site My Cloud: it can´t get to the device
Last discovery: I rebooted the device. Once I could ping it from my PC, I could map the drives and browse content normally. Device´s led was still blinking in white. As soon as Device´s led turned to “blue” I heard a funny noise and the problem came back, performance went down to zero, I can´t browse directories, nor connect with WD My Cloud.
Any idea? Suggestions on what should I check, reasearch? Someone with the same issue? Firmware issue?
Thanks a lot and best regards
Ignacio
