MyCloud Mirror stuck in amber and blue power cycle and not showing on network
Hi
I have a 8TB mycloudmirror (2*2TB) which has been running away for a number of years quite happily
Recently I did notice a red light for a few second on disk 1 - so I restarted it but now the power light flashes orange then back to blue, lots of disk whirring sounds but then it stops and start the cycle again - ie power light flashes orange, disk whirring sound the power light flashes blue then back to the orange – it also does not show up on the network – no ip address
The disk 1 and 2 lights are blue
I have read the orange flashing can be network and indeed the Mycloudmirror does not show up on the net work
As there had been a red light on disk1 – I pulled disk1 and tried a reboot without it in and it works fine on just disk2 in slot2– starts up , shows up on the network and no issues
Figured it was the disk and bought a replacement – powered the unit down, put the new disk in slot 1 - and no luck - ended up back in the powerlight flashing orange and blue cycle with lots of disk whirring sounds and not showing up on the network - disk1 and 2 lights are blue – pulled the new disk1 back out of slot1 and it boots up fine again on just disk 2 in slot2
I looked at the storage utilities and it shows the disk2 profile as good
Then pulled the working disk2 and put just the original disk1 back in slot1 - (should have tried this before I purchased a new disk) and with the original disk1 in slot1 and no disk in slot2 – it booted up but had a blue flashing powerlight and a red disk light
And when I looked at the storage utilities, it showed the disk1 profile as bad – so I guess it does need replacing so not feeling so bad about buying the new one
I then pulled the disk1 and just tried it in slot 2 to see what would happen – and again it booted up
Then put the original disk2 in slot1 to see what would happen, boots up and still shows disk2 as good
Then lastly just put the original disk1 in slot1 and disk2 in slot2 - so back to where we started and it just booted up – what a surprise - utilities show disk1 as bad and disk2 as good and Raid shows Volume_1 as degraded - and there is a red light on disk1 on the front of the unit – so assuming disk1 is bad
So replaced the bad disk1 in slot 1 with a new disk and it went straight back into the power light flashing amber and blue and disk whirring cycle - and the device does not show up on the net work and wont boot up
Just to complete the test - I put the original disk2 in slot1 and the new Disk1 in slot2 – and again it just goes to the power light cycle of amber and blue and disk whirring – does not show up on network, no ip address
Then took out disk2 and just put the new Disk1 in Slot1 and it started up - showed disk as good but no configured volumes etc which is the case as it’s the first time this disk has booted up or been used
The left the new disk1 in slot1 and added Disk2 back into slot2 and– again back in to the power light cycle of amber and blue and disk whirring and not showing up on network
Now given up for the day and just removed the new disk1 from slot1 and left disk2 in slot2 - booted up fine so I least I know I have my data
Have been using my broadband router “currently connected devices” page so I know when its there or not and has and ip address and the standard mycloud mirror page for information – which is only available when the device has an ip address and on the network
So question is – how do I get this to boot up with a new drive as when it has 2 disks in it gets stuck in a loop
Any advice appreciated
Hello MarkT,
I would suggest you to contact WD support for assistance as it seems that there is some issue with the hardware of the device.
