Forgive me if this has been addressed, I searched and could not find an an answer anywhere.
I have a Mycloud Mirror 8gb, connected to an Apple Airport Timecapsule Extreme, via a CAT5 cable. The Airport is connected to the cable modem via a CAT5 cable as well.
The Airport is a gigabit router, yet the mycloud mirror only sees it asa a 10/100 connection (light on the lan port is green). My understanding is that if you are seeing gigabit seppeds the lan light is yellow.
So… I have tried swapping cables, with no effect. Is there a setting I am missing? Do I need to buy a seperate gigabit switch and just hook everything into it? I havent tried assigning a static IP, but i can’t believe that will have any effect on my issue.
Please help!
Steven
