Hello.
I was trying everything (I think), still no luck…
The problem is: on home network, with 1Gb router, on cat6 cables MyCloud can reach only 13-15MB/s transferring files (size doesn’t matter) to my desktop PC. Writing speed (back to MyCloud) is normal- around 50MB/s. So far I was trying:
another PC with 1Gb ethernet card - the same result
MyCloud connected direcly to PC - the same result
installing clean debian on MyCloud - the same result
upgrading samba to samba4 (with/without tweaking) - the same result
downgrading software to v.3 - the same result
checking cables - on the same cables my MyBookLive reaches 70MB/s reading speed
Full restore on MyCloud - the same result
Is it possible that official update (v.4) install some sort of firmware into MyCloud (does it has a flashrom?) ? Maybe this update changing share speed for good?
Can someone help me resolve this problem?
