I have a new My Cloud EX2 Ultra.
Since the update to My Cloud OS 5 only the bottom LED is on and shows always solid blue.
I’m using it in RAID1.
Is this a OS bug or is there anything else wrong?
It seems to work normal as far as I can say.
Well, these LEDs are notorious for going dead. Maybe the top two died and this is just a coincidence(?)
Thanks for the reply. The upper one can be orange on startup for a second^^
I just wanted to be sure that this isn’t some known failure code.
Not that I’m aware of. Oh, and these individual LEDs can be several colors (orange, green, red) and it’s the most used blue color that burns out (you can change them all to green under software and they will probably all work).
