how do i correct mount the complete sda4 in mycloud via ssh.
df
Filesystem 1K-blocks Used Available Use% Mounted on
rootfs 1968336 1709568 158780 92% /
/dev/root 1968336 1709568 158780 92% /
tmpfs 40960 3776 37184 10% /run
tmpfs 40960 64 40896 1% /run/lock
tmpfs 10240 0 10240 0% /dev
tmpfs 5120 0 5120 0% /run/shm
tmpfs 102400 1984 100416 2% /tmp
/dev/root 1968336 1709568 158780 92% /var/log.hdd
ramlog-tmpfs 40960 19008 21952 47% /var/log
need instruction to Mount:
CacheVolume
DataVolume
shares
Mount -t ext4 /dev/sda4 /DataVolume work but need help with CacheVolume and shares
Manual Firmware recover Ends up with error:
CrashCloud:/shares# /usr/local/sbin/updateFirmwareFromFile.sh /DataVolume/sq-040403-113-20160510.deb
updateFirmwareFromFile.sh:09/25/16 09:44:45:: ( /DataVolume/sq-040403-113-20160510.deb )
updateFirmwareFromFile.sh:09/25/16 09:44:45:upgrade start: /DataVolume/sq-040403-113-20160510.deb
updateFirmwareFromFile.sh:09/25/16 09:44:45:check_size=
/usr/local/sbin/updateFirmwareFromFile.sh: line 195: internalDrives: command not found
Error fw_update_status: failed 205 “all drives must be present for upgrade”
updateFirmwareFromFile.sh:09/25/16 09:44:45:failed 205 “all drives must be present for upgrade”
send_update_log=200
/etc# updateFirmwareFromFile.sh /CacheVolume/updateFile.deb
updateFirmwareFromFile.sh:09/25/16 12:56:25:: ( /CacheVolume/updateFile.deb )
updateFirmwareFromFile.sh:09/25/16 12:56:25:upgrade start: /CacheVolume/updateFile.deb
updateFirmwareFromFile.sh:09/25/16 12:56:26:check_size=
updateFirmwareFromFile.sh:09/25/16 12:56:26:failed 205 “all drives must be present for upgrade”
Make sure that you have a folder named /nfs Then
mount -t ext3 /dev/sda4 /nfs/Public
mount -t ext3 /dev/sda4 /nfs/SmartWare
mount -t ext3 /dev/sda4 /nfs/TimeMachineBackup
First time i have installed the teanazar webmod with an wordpress.
second time i uninstalled the package Manual with apt-get remove 2 month ago
at thurday i want to actualize my Debian,
apt-get update
apt-get upgrade
apt-get autoclean
after this i have Problem with
The following packages have unmet dependencies:
libtirpc1 : Breaks: nfs-common (< 1:1.2.8-7) but 1:1.2.6-4 is to be installed
Breaks: nfs-kernel-server (< 1:1.2.8-7) but 1:1.2.6-4 is to be installed
reboot
and then the Trouble Begins
i think at check the Mount nfs/all .sh the Firmwareupdate will work again if the Partition are correct Mount and bind to the right Folders.
Yes… apt-get is a potential disaster on the v4 firmware MyCloud, because v4 is built with a 64k block size, rather than the 4k block size used for standard Debian repositories. You now probably have an unholy mess on your device…
If you can get firmwareupdate to run, and run a system restore, you may be okay. If you don’t have your data backed up, I’d try to do that now…
If you can’t resurrect your device with the method you’re using, you may have to use one of the unbricking methods to restore the firmware, after saving your data from the drive.
