Ok Ive searched and searched but cant find out if what I want to do is possible but everything I read before I bought the Mycloud Home device seemed to make me think I can do what I want to do.
My Mcloud device is a few years old (4Tb Drive) and Its getting to the stage where I am concerned if it fails that I will lose a bunch of stuff.
I bought a new 4TB Mycloud Home device and I had hoped to have them sync the same way the old WDMcloud devices should have done (I cant buy the older device now I dont think other than used) but I cant find a way to do this.
So I have 2 x WD Devices @ 4TB each that i essentially want to either mirror or have 1 of them sync to the other nightly etc …
Whilst it will do what I need it unfortunately needs to be proactively kicked off on the Mac and doesn’t seem to just let these 2 devices work together without the Mac/pc running the program.
The issue is really the Mac having to run for it to work . real time sync is great but with multiple devices adding data it’d be , I think , unsync’d until I fired up the Mac …
