MYbook Live setup 'There seems to be a problem...' message
my previous laptop broke and I’ve got a laptop running Windows VISTA and one running Windows 7 that I’m trying to map to my existing MyBook LIVE (2TB). I can access the dashboard OK and log on and setup shares and users but I’m unable to map a drive as it doesn’t recognise my credentials (even if I use the same ones as in the admin logon). I’ve tried running the set-up software but this comes up with and error:
'there seem to be a problem
we’ve detected that you may not be able to:
x copy files to or from the device
x browse the devices shared folders
x map a shared folder’
Has anyone else come across this or have any ideas what to do to get it working?
Are you able to map the “Public” share?
