I’ve been having this problem for a while and its coming to a point where I can’t take it anymore. The smallest movement on the usb causes it to disconnect from my pc. This is very annoying because its very slow when transfering files and after waiting for 20minutes and just have it disconnect suddenly is annoying. I’ve tried the Amazon USB cable because I’ve been told that it might just be that the original usb is to small…
My question is: Can I transfer all the files in it currently to my pc/another external hard drive, then remove the hard drive from MyBook and place it on a different case?
thanks in advance
