All,
I have a MyBook Duo that I’ve been using as my main storage drive for my photographs.The drive is set up as a RAID 1 array, and I import my photographs into Adobe Lightroom without an issue. The program sees the drive, writes to the drive, and I can access files through the Mac OS X 10.12 Finder without an issue, as well as within Lightroom without an issue.
However, when I installed DxO Photolab Elite 2 to begin using it, the program doesn’t recognize the drive. It says there are multiple drives with the same UUID assigned. I know there are ways to change the UUID, but I’m not sure it’s something I want to do, for a variety of reasons, not the least of which is the amount of data that’s on the drive, as well as I would want to save all of the files to another location just to be safe.
Other than inserting yet another drive into my workflow (i.e., import images onto a single drive, and then also copy them onto the MyBook Duo), anyone have an idea how to resolve this issue? As it is, I can’t use the MyBook Duo drive with DxO Photolab Elite.
Thanks,
Sam
