Hello Every one
Thank you for allowing me to join your forum, I have a wd external drive with lots and lots of information ,which I would like to keep but since windows has carried out several updates I cannot power it up .
I have now made a thorough check of all the connections , renewing the fuse and testing it as much as I know how but still no luck .
Would you help me please !!! Thank You All in Advance. desmo11225
Hello, desmo11225
Well, WD® does not recommend to tear up the drive in parts as it will lead to void the warranty of the drive.Moreover, if you want to extract the data from the drive please get in touch with data recovery company.
