My WD Elements 2TB USB portable drive changed to RAW
How can I get it back to Ntfs?
To get the unit back to NTFS, you will need to reformat the drive. If you had information on the drive that you need, I’ll recommend you to use a data recovery software to get the data out of the drive and then try to reformat the drive to change it to NTFS.
Thanks for your response but I get this error when I try to format it. “The request failed due to a failed due to a fatal device hardware error. “
Nigel
