Will this work with movies being in their own inndividual folders or do they have to be all in the same folder together?
Added some more movies tonight to get the count above 24 and there is a bug when changing to 2nd screen, part of the screen moves before the rest.
It is cured by a reboot however, and works until you change modes again.
Its not a major issue for me, as I rarely have more than 24 movies per folder.
Seems the bug I had with part of the screen lagging behind was to do with what part of the screen is designed to scroll.
So have had to rearrange the thumbnails using only the scrolling part and text in the non scrolling part.
^ Hope that makes sense, I’m knackered tonight
Not sure about the 3 rows of 10, I want to try 3 rows of 9 tomorrow
PS. the films without thumbnails are just empty files to use as padding for the test.
I agree - think this is the problem. Your new setup will probably solve it…
zballz wrote:
I’ve done a similar (almost identical) setup now. Looks good, but very buggy unfortunately. I’ve set mine up, so that you can scroll up/down to go up-down the wall. Going down is pretty smooth, but going up is slow and gets really buggy. How have you set yours up regarding navigation?
heres what I’ve done :
<listbox valkey=“browselist” move=“row” cols=“6” rows=“4” lbmask=“LR” loop_scroll=“6” _trigger=“10” turbo_multi=“10” autoenter=“1” fixed_scrolling_col=“6” hormove=“0” />
Please read my post about the hormove=“0” being buggy. A WD mod is showing interest in this, and I think it would help if others could confirm what have written there.
done
My final design, happy with its looks now. Might go back and look at the other design if they fix the issue with it. This one however works fine I will upload the file tomorrow if anyone wants a copy
I would love a copy.
Thanks in advance.
Hi guys, I’m doing a similar modification but with the large video browse file. Everything looks cool but there is one little problem. Would you be so kind to check out my thread and see if you can help me out?
http://community.wdc.com/t5/Themes/Need-some-help-with-this-Legacy-modification/td-p/140636
BTW the view you’re making looks great. I’m looking forward to test the file on my hub.
Thanks for your time.
id like to try it out too!
Looks Great, and can’t wait to try!!
Here’s the file chaps, don’t think I’ll be changing it again, unless someone knows the code for the weather icon and temp, then I’ll put that in the top left to mirror the clock.
http://hotfile.com/dl/106988540/21a9982/rv_gallery_browse_page.xml.html
feedback welcome
Mark
very nice mark, very nice
Thank you for the code. Love the layout.
Viewing it on my 42" TV looks great, on my 50" the top where the time and title of movie is cut off. Its not bad but you def can notice.
Thanks,
I would suspect that your 50" TV settings can be tweaked to show the top. I’ve moved things close to the edge of the screen, but they should all be positive value and be visable.
Thanks for the upload Skid! Much appreciated.
However please excuse my ignorance, but how do i insert this into the theme and also will this work with any theme?
Thanks.
connect to your box, browse to the theme folder and drop the file in the folder of the theme your using.
Cheers, but do you need to delete previous gallery file?
nope, if theres one there already, it will prompt to overwrite it.
cheers skidmark, will try it out tonight!
BTW- cracking name LOL
