Ane news about fixing issue?
Can I buy MPWP + SDSSDA-960GB-G26 instead of SDSSDHII-1T00-G25?
Can I use this workflow:
put SD card and attach USB SSD and copy files from SD to USB SSD with phone via wifi?
Successfully upgraded MPWP 3TB with 512GB SSD
Hi guys,
thanks to all for all information you have posted here, based on them and after a few trials and stucks I have managed to convert MPWP 3TB to MPW SSD with Sandisk X600 512GB. My steps are following, and some of them may be unnecessary:
Question is if it was worth all the time invested, but Iβm satisfied now and also I have learned lot of things about linux thanks to this
Hi Divovlas, can you upload image from system partition from your MPWP?
mi try to repair my MPWP but i need system partitions
Thank you, please help me - how to restore from your image? Iβm nub in linux
Me too, so no guaranties Reading about dd command will help. As I understood, this command is able to copy anything to anywhere, so there can be severe causalities when not used properly, like destroyed boot sectors, partition tables or filesystems. You have been warned.
These MPWP system partitions are not visible to classic partition programs - as they are marked as deleted/hidden. So this is byte to byte copy of disk sectors after the regular partition for data.
dd if=image_file of=/dev/sdx bs=512 seek=write_at_sector count=8457136
sdx = new disk (sda, sdb, sdc, β¦)
write_at_sector = total new disk sectors - 8457136
from the beginning of the disk to (write_at_sector -1) sector there is a place for regular exfat or NTFS data partition
Thank you so much, but repair my MPWP is fail
?hbj
U-Boot 2012.07 (Dec 17 2015 - 01:19:14)
CPU : Cortex-A7 dual core
Board: Realtek QA Board
DRAM: 512 MiB
Watchdog: Disabled
Cache: Enabled
Non-Cache Region: 1 MB@0x07900000
nor flash id [0x00c22017]
sector 256k en: 0
sector 64k en: 1
sector 32k en: 0
sector 4k en: 0
page_program : 1
max capacity : 0x00800000
spi type name : MX 64Mbit
Factory: NOR
Factory: pp:0, seq#:0x2, size:0x200
get_bootparam:
Factory RO: NOR
[ENV] read_env from factory failed
[ENV] Using default environment variables
In: serial
Out: serial
Err: serial
Net: Hit Esc or Tab key to enter console mode or rescue linux: 0
[PMX] : GPIO checkβ¦
[PMX] : Get GPIO 18 = 0
[PMX] : Press battery status buttom, go into recovery modeβ¦
[PMX] : prepare recovery configβ¦
(Re)start USBβ¦
USB0: USB EHCI 1.00
scanning bus 0 for devices⦠1 USB Device(s) found
scanning usb for storage devices⦠0 Storage Device(s) found
1: Hub, USB Revision 2.0
hash 2(base=0x01452c80)
000 : fa aa 84 bc 3c a9 39 c7 69 1b e8 42 86 7b 53 33
010 : d7 47 6b fc e7 72 30 08 cc 08 a4 d0 05 56 e6 8f
Start bootcode2 at 0x01400000 β¦
U-Boot 2012.07 (Dec 19 2016 - 15:36:21)
[WARNING] TLB was overlaped with kernel. (addr: 0x014b0000)
DRAM: 512 MiB
Watchdog: Disabled
Cache: Enabled
sector 256k en: 0
sector 64k en: 1
sector 32k en: 0
sector 4k en: 0
page_program : 1
Factory: NOR
get_bootparam:
Factory RO: NOR
In: serial
Out: serial
Err: serial
Firmware Version: ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
FWtable CheckSum error: fwtable_crc32[6a3b8a21], fwtable.checksum[ffffffff]
[PMX] : recovery fail
(Re)start USBβ¦
USB0: Realtek-ehci: init hccr 18020000 and hcor 18020020 hc_length 32
RTK USB3 phy init
No power optimization available
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices⦠Unknown request , typeReq = 0x200c
2 USB Device(s) found
scanning usb for storage devices⦠4 Storage Device(s) found
1: Hub, USB Revision 3.0
2: Mass Storage, USB Revision 3.0
** Partition 1 on device 2 is not FAT filesystem **
** Unable to use usb 2:1 for fatload **
[PMX] : prepare firmware form USB fail
[PMX] : prepare normal firemware configβ¦
[PMX] : Enter RTK recovery procedureeβ¦
Enter console mode, disable watchdog β¦
Lot of " Partition 1 on device 2 is not FAT filesystem" errors - what format is your data partition? And SD card? SD card should be formated to FAT32
Of course, i try to format Data partition to exFat, NTFS, Fat32. EXT4, try to use SD with FAT and FAT32, but recovery doesnβt see fat partitions.
In recovery via UART and Putty has a command usb - i try to usb part, but with any connected HDD i see
that disk have a 1tb ( i try ssd 256) and have a partitions 1g 1g 2g - but ssd hasnβt this partitions.
Does anyone have a sense of whether the method described above (by Divovlas) works with other capacities of SSD in the x600 line? As in, the 1TB version of the x600?
It depends on if itβs detected or notβ¦ if itβs detected, the process should work fineβ¦ I had an issue with a Samsung SSD not being detected for some reason. Sadly, before I was able to test a modified script that wrote a lot of debug info to the SD card, I lost it and I didnβt have a backup on my nas.
Always remember to backup files that you spent more than a couple minutes on and triple check itβs the latest copy! Iβm currently in process of going through the whole script and making comments on what each section/block does. Iβm hoping to finish the commenting tonight/tomorrow so I can start on the modifications again.
I have success using a m.2 WD blue 1TB SATA + 2.5 enclosure using the SD card method. All using Windows Disk Manager
Initially when I went to the GUI, I realize the reporting size is like 768MB! Plug the drive into Windows and I do see 1TB, so I went to the admin tab and do a factory restore (with disk option), after the next reboot, it shows up at 1TB now. Even the picture shows up as My Passport Wireless SSD!
Great tip, Jayband, very helpful! That worked for me with a WD Blue M.2 1TB and a third-party M.2-to-SATA enclosure. (Incidentally, I didnβt find I needed the βddβ step Divovlas was unsure of above.)
After some experimenting, Iβve managed to get it to work on:
WD Blue 1TB SSD 2.5"
Lite-on 240GB SSD 2.5" (OEM)
And failed on:
Samsung QVO 1TB SSD 2.5"
ADATA SU800 128GB SSD 2.5" (Somehow bricked this one, becarefulβ¦)
The only conclusion I can draw from this is it will only work if it is a SATA SSD with a Marvell controller.
However, my sample size is too small to draw any definite conclusions, so for anyone that has a MPWP and a Marvell controller SSD, it would be great if you could give it a shot and report back!
Just follow the steps outlined by Jayband (step 1 did not create a 200mb partition for me) and report your results!
Also note that the password from serial is not the last 8 characters in the serial, but more specifically is (from memory) something like the 4th-12th characters in the serial, excluding stuff before the dash etc. Use command prompt/terminal to check the serial of the drive and then count the characters.
my hard drive started clicking and the lights blinked so i searched and came across this thread.
Thanks to the info in here i was able to change out the hard drive to one i had available, i think it came out of an old laptop.
i canβt seem to find the password though. i entered the SN of the replacement hard drive (its only 8 characters in total) and it didnt work. i tried my old changed password, i tried the old hard drive SN as the password. does anybody have any suggestions? yes i tried 6P240WJN and 6p240wjn
attached is an image of the hard drive i put in it.
Hi, the label is a little off from what is actually read.
Plug the hdd into a computer and read it that way.
In windows, open command prompt and type:
wmic diskdrive get Name, Manufacturer, Model, InterfaceType, MediaType, SerialNumber
This should give you a serial. The length might differ from your original drive so you may have to guess and check where the 8 characters starts and stops. It should be something like the 4th to 12th characters.
Tell us how it goes!
thank you for your information, does the NAS function work well on your changes or still malfunction as mentioned above?
thanks.
Everything works just like a genuine βMy Wireless Pro SSDβ
@Newzj82 the wifi password is stored in the following files:
/etc/nas/config/wifinetwork-param.conf:AP_ENCRYPTION_KEY="AAAAAAAA"
/etc/nas/config/wifinetwork-param.conf:AP5G_ENCRYPTION_KEY="AAAAAAAA"
/etc/hostapd/hostapd.conf.2G:serial_number=WX71AAAAAAAA
/etc/hostapd/hostapd.conf.2G:wpa_passphrase=AAAAAAAA
/etc/hostapd/hostapd.conf.5G:serial_number=WX71AAAAAAAA
/etc/hostapd/hostapd.conf.5G:wpa_passphrase=AAAAAAAA
/etc/wpa2G4_supplicant.conf:serial_number=WX71AAAAAAAA
/etc/HDSerial:WX71AAAAAAAA
/etc/wpa_supplicant.conf:serial_number=WX71AAAAAAAA
You should be able to DD the last 4gB of the disk to a file, open it in a hex editor, and search for wpa_passphrase= On Windows you can use DiskInternals Linux Reader, right click the unallocated space, click hex preview, and search for wpa_passphrase=
In order to get @jayband 's process to work I needed to create a partition in the remaining 4130mB and format it to fat32 using a slow format, and then delete the 4130mB partition. The OS is stored in that unallocated slack space and if you donβt properly delete it you may have some issues.
If you extract the firmware update file with
tar xf file.bin
Thereβs a rootfs.tar.gz if you extract that you will have a filesystem that gets written to disk in
/etc/init.d
Youβll see a bunch of scripts that run at boot. Inside S60hostapd there is a βReGerneateSSIDβ function that creates the password from the HDD Serial number using hdparm. If you are unconfigured it will generate the password using this.
SN=
/usr/local/sbin/getSerialNumber.sh | cut -c 5-12
Which calls
serial_number=
hdparm -I ${Node} | sed -n -e 's/.*Serial Number:\(.*\)/\1/p' | sed -e 's/^[ \t]*//' | awk '{gsub("WD-","",$0); print $0}'
If you are configured it will call a similar function. So if your serial number is 6P240WJN your password will be the last 4 digits 0WJN. Which is going to cause some issues because wifi passwords need to be at least 8 digits. I have a seagate drive that is in the same boat that Iβm trying to figure out. Perhaps @PuDLeZ can better explain how you use losetup so we can fix this script.
