I have a My Passport 2TB which worked fine using old Win10 laptop. I upgraded my laptop and am now using a USB Hub to connect my devices to this laptop. The laptop’s USBC 3.0 port is able to find My Passport and assign a Drive letter to the device. However, I need to use the USBC 3.1 port because of its charging feature when docked and this particular port does not assign a Drive letter when plugged in. The device shows up in Disk Manager as healthy, but also shows up as GPT Protective Partition. I have transferred all the files off the device and reformatted the drive in order to remove this feature and now that Drives shows up in Disk manager. I believe I need to create partitions next but clueless if it should be a NTFS partition or MBR partition.
Thanks Joe
