Autoplay doesn’t recognize it anymore nor does it show up in My Computer or even if I run a cmd disk check. It shows up in device manager, but there are no volumes on it according to dm (funny, cause there should be over 150 mb of stored data) and I can not access it. **bleep** gives? It seems that many people are having similar problems. Mine crapped out after only a few months.
Well… If you did check disk management and the drive is not there, then the only things left are to try a booster cable (USB cable shapped as the letter “Y”) and then a replacement. Try also a firmware upadte, it has helped some people bring them back to life.
