For no apparent reason, the unit no longer boots. The blue power light blinks indefinitely. Also, the lights under the ethernet ports on the back illuminate very dimly. I’ve tried the reset button several times with no luck. I’ve tried a power pack from one of my other two units, no luck. I also cannot access the internal settings through the internet browser, presumably because it never connects to the network. I bought these in December 2013, so they are out of warranty. Any help would be greatly appreciated.
Unit could be dead and you may need a replacement. But before you do so, take the other Bridge off line, but leave all the other parts there, like PS and Ethernet cables, etc. Put the wonky unit in its place. If it works, then it is likely still good, and if not, you just confirmed it is bad, and likely can’t be fixed.
Also, I am leaving you a private message, so be sure to see it…
I replied in another PM to you.
