My MacBook Pro dropped My Book after Sequoia 15.8 - help!
Was working well for years with Time Machine back ups and then today’s Sunday morning Apple macOS upgrade wiped it out . Have tried the different wall plug and disc utility / first aid suggested cures but no luck. I guess I have to try and someone with another computer to test it out ?
There are a number of reported issues with Sequoia although with earlier revisions.
Try turning off the firewall.
Hi - thank you for the helpful reply. I appreciated it :blush: I did turn off the firewall and re start it but no luck. Will investigate the Apple forums.
