Hello I am trying to interrogate the data volumes stored on my 1 Tb My Cloud personal storage I have the My Cloud Device connected to my home router and network accessed by 5 computers.
The 1 Tb device has 912 Gb of usable storage. According to the user folders stored on the My Cloud Device viewed via File Explorer they total to 84 Gb. Storage on the device currently indicates 767 Gb Used and available storage is 144 Gb. Last week when unable to save any additional files to the device I removed several folders of data not required to be accessed via the 'network to another storage device.
My concern or issue is how to investigate the discrepancy between the 767 Gb of used space showing on the MyCloud device and the 84 Gb of data that the folders according to File Explorer contain. i.e. A difference of 683 Gb of data. Is there a tool or a report that is available that will provide details of what makes up the data stored on the MyCloud device? I do not store ‘safepoint’ files on the MyCloud I use a MyBook HD attached via USB to the MyCloud and detach when the safepoint is completed.
