i have a problem with capacity. I made few sync folder on my computers. Everything works good until today. My EX2 is over 95% of capacity but sync folders has just 60GB size together. Where could be a problem?
Hello peter.wlk,
You should try checking the data stored in the device’s Sync share and click on the properties of the share where your data is syncing in order to check the occupied space in the device (My Cloud EX2).
