Hi there
Thank you for your reply, I realy need help here.
That is WD My Cloud 4T single unit, SN WCC4E0464149.
It is connected to my local network router.
Yes, I tried a different cable, different power cable, checked all 4 networking ports on router. Nothing changes.
I tried connecting My Cloud to my laptop with Windows 10 on it but it is unrecognizable.
I tried wia USB cable and tired to find it in all kind of diagnostic applications but no…
The part with router’s administration page… I am logged in, the router its FritzBox 6490 Cable.
My Cloud should be under 192.168.178.30
The seetings are as follows:
Is it ok ?? I have not so much idea about routers…
And the LED in front od My Cloud ist since one week solid amber, blinks once per few minutes, it never goes to green.
Do you think the disc could be damaged ?
Thank you!
Kate
