My Book World Edition II (blue rings) problem connecting to Smart TV
Hi im trying to view my NAT files on my LG smart TV but its not showing up on the TV’s menu, iv just update my Nats firmware to 02.00.19
Are you able to see the drive from any other device on the network?
Have you check that the drive is fully compatible with that TV?
Yes iv been using the drive on my network for years wothout any problems.
from reading the manual the only thing i can see wrong is theres no default share folders on the drive anymore, anyway to restore them without a format?
