Hi!
I have some pre-buying questions about My Book Duo 6 TB
We are a couple of freelance translators and we need some place to store common files (for example, translation memory files).
Is it possible to use the same file at the same time from two computers? (as it occurs in google-docs, for example)
Is it possible to create common folder for two computers and share files between them?
3. Is it possible to install soft on My Book instead of on local disc C:/ on my computer?
Thanks! :smiley:
