This is my 3rd NAS drive and i think i am about to just give it away if i cant seem to fix whats going on now. I hooked the drive up and use the Software and it loads fine till it get to a point in the install it says it cant connect to the server. so i try to use the direct IP to the dash board EG: 192.168.0.15(say that was the IP) it IE FF or what ever breoswer i try i get page cant be found. BUT i can go to my networkthe drive is there i can access it and i delete more save files to it and works fine BUT i can Update firmware set the drie up or anything. anyone please help me with this i even went as far as to redo windows 7 on a clean install and sitll the same problem.
One other thing i forgot to post is i can access the Twonky configure screen with out an problmes
EG: 192.168.0.195:9000 comes up i can make all the changes i want but like i said when i go to use the 192.168.0.195/UI to get to the dash board no matter when browser i sue it says page not found and WD Software during setup says it cant connect to the server.
