My Book Duo click noise and wakes every 60 minutes
Support says there should be no noise but checked reviews on amazon, youtube and these drives definitely click, it is kind of soft click not metallic one. I would like know if anybody experiences same.
More important problem: checked power options, turned of defrag, chkdsk windows tasks, no telemetry, indexing, windows search and drive still wakes every 60-63 minutes, net session shows no sessions. How to prevent hourly wakeups?
To recover data from your desktop after data loss, stop using the system immediately to avoid overwriting lost files. Check the Recycle Bin to see if the deleted files can be restored. If you have a backup, use it to recover the lost data. If not, install reliable data recovery software, scan your desktop, and recover the files. Save the recovered data to an external drive. To prevent future data loss, regularly back up your files and keep your system protected from viruses.
