It does still work, you just have to enter the words quick in the checker app.
Oh … i just checked in before catching some zzzzzzzzzzzzzzz’s
I clicked the hotfile link and i got the same thing… ?
Anyways,i quickly setup a Mediafire Account just now… hope there are no problems (will check back in 8hrs)
BOTH VERSIONS: WHITE & DARK
http://www.mediafire.com/download.php?706yppnen4mv61y
I will update/add this link on page (1) as well.
Hello Joey,
I am using your Theme and it is very good,I have seen your Aeon experiment and it looks great.
Could you tell me how to merge it with your Gallery Moviesheet/Thumbnail Trick so as i get the pictures showing
Many Thanks Dave
just copy images in image folder + xml files of AEON into the theme folder load the theme on hub & u r done
Many thanks will give it a go
Where do you get your backgrounds from? Love the tron one.
Google Images
