Have you pluged it into router directly. Then goto the router to see if dhcp has picked it up, or plan plug it directly into the computers network port to see if you get any responce. The other thing you could check is the power unit is properly clipped togther and if you have a meter you could check that you are getting voltage out off the power plug. Also can you hear the harddrive spin up when power it up? That all I can suggest, then the only thing is left is to take it back Good luck M
It could be 12v most of the harddrives I have are that you might a bit higher off load. I know this sounds stupid have you pressed the power on button on the back of the unit? But this most probely no different to the question you would get asked from a help desk. GL M
OK, I’m putting my hands up and stating this was user error:cry:
When you first connect the power cable, the unit must go through some sort of test cycle and then power down. You have to then press the power on button at the back.
Now onto all the other issues I have, (I hope their not down to my own stupidity:stuck_out_tongue:)
