I have 2 ex2 Ultras (1@home, 1@work). I used the same email for the MyCloud account. I can access both remotely through the app on my iphone but through MyCloud I can only remotely access the one at home. I’m guessing it is possibly a port forwarding issue on the work unit. The other issue is that on my laptop (Windows 10) after logging into MyCloud it just sits at the “Signing in…” screen.
Android or iOS?
Mobile App (Carrier Network) - can you access both EX2 Ultra
Mobile App (Home Wifi) - can you access both EX2 Ultra
Mobile App (Work Wifi) - can you access both EX2 Ultra
MyCloud.com (Work Network) - can you access both EX2 Ultra
MyCloud.com (Home Network) - I understand that MyCloud.com (sign in) hangs ??
Is the EX2 Ultra at home in port forward mode?
Is the EX2 Ultra at work behind more than one router? IE: Double NAT’d force Relay Mode
What ISP / GATEWAY / ROUTER / SWITCH are you using at home?
[Android or iOS?] iOS
[Mobile App (Carrier Network) - can you access both EX2 Ultra?]-Verizon. Yes everything is good with mobile app.
[Mobile App (Home Wifi) - can you access both EX2 Ultra?]Yes
[Mobile App (Work Wifi) - can you access both EX2 Ultra?] Yes
[MyCloud.com (Work Network) - can you access both EX2 Ultra?] No only the Home unit.
[MyCloud.com (Home Network) - I understand that MyCloud.com (sign in) hangs ??] Only access home unit. Hanging problem was a popup blocker on the laptop. Now resolved.
[Is the EX2 Ultra at home in port forward mode?]-Yes it is.
[Is the EX2 Ultra at work behind more than one router? IE: Double NAT’d force Relay Mode]-Yes it is
[What ISP / GATEWAY / ROUTER / SWITCH are you using at home?]-Have both AT&T(DGND3700v2) and Time Warner(WNDR4500v2)
it’s possible your corporate IT network is blocking or filtering inbound calls or traffic.
I’ll have one of our support members reach contact you and assist.
