Multi zone audio output
I will be using this unit to play video from a USB hard drive through the HDMI cable. I would also like to use it for playing MP3 / M3U playlists and send the audio out to a Zone 2 amp.  My AV amp requires a analog audio signal in to send an analog audio signal out to the zone 2 amp. Does this unit output analog and digital audio simultaneously, or will I have to go into the setup menu and change it back and forth manually?
Hi there, you’ll have to manually change the output on the settings when needed.
I asked this same question here:
http://community.wdc.com/t5/General-Discussions/hdmi-and-composite-audio/td-p/205046
and got the opposite answer.  And I confirmed that it works.
