I’m having issues playing MPEG files. The media player runs for a few minutes than quits. If you want to fast forward to a specific time, it doesn’t show the videos full playback time. I’ve restarted the player with no luck. I checked the specifications, and it’s supposed to work. The video file specifications are the following:
General
Complete name : C:\Back From The Mall.mpg
Format : MPEG-PS
File size : 770 MiB
Duration : 31mn 45s
Overall bit rate : 3 389 Kbps
Video
Format : MPEG Video
Format version : Version 1
Format settings, BVOP : No
Format settings, Matrix : Default
Duration : 31mn 45s
Bit rate mode : Variable
Bit rate : 3 127 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.142
Stream size : 710 MiB (92%)
Audio
Format : MPEG Audio
Format profile : Layer 2
Duration : 31mn 45s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 29.1 MiB (4%)
Could anybody help on this?
