MPEG-4 problem
Problems with this movie
go with interruptions
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : Yes
Format settings, QPel : Yes
Format settings, GMC : 3 warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 50mn 8s
Bit rate : 1 745 Kbps
Width : 720 pixels
Height : 400 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.242
Stream size : 626 MiB (90%)
Writing library : XviD 1.2.0SMP (UTC 2006-01-08)
the problem is …
Have you search the rest of the forum about this? I’d give it a try. Or, have you tried contacting WD’s Technical Support about this? I would consider giving them a call or sending them an email.
