MP4 No Sound
Hi guys I have a  WD TV HD Media Player (Gen 2) WDBABF0000NBK-00 with the last firmware 1.01.77  but when i try to play a mp4 file there`s no sound.  The file atributes are:
General
Complete name                    : C:\Users\Administrador\Desktop\dr\movie.mp4
Format                           : MPEG-4
Format profile                   : Base Media
Codec ID                         : isom
File size                        : 105 MiB
Duration                         : 43mn 55s
Overall bit rate                 : 335 Kbps
Encoded date                     : UTC 2010-03-26 17:10:48
Tagged date                      : UTC 2010-03-26 17:10:48
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L5.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 8 frames
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 43mn 55s
Bit rate mode                    : Variable
Bit rate                         : 268 Kbps
Maximum bit rate                 : 688 Kbps
Width                            : 640 pixels
Height                           : 360 pixels
Display aspect ratio             : 16:9
Frame rate mode                  : Constant
Frame rate                       : 29.970 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.039
Stream size                      : 84.2 MiB (80%)
Writing library                  : x264 core 56 svn-676
Encoding settings                : cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=5 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=268 / ratetol=1.0 / rceq=‘blurCplx^(1-qComp)’ / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Tagged date                      : UTC 2010-03-26 17:11:32
Audio
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format version                   : Version 4
Format profile                   : LC
Codec ID                         : 40
Duration                         : 43mn 55s
Bit rate                         : 64.0 Kbps
Maximum bit rate                 : 70.2 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Sampling rate                    : 44.1 KHz
Stream size                      : 20.1 MiB (19%)
Encoded date                     : UTC 2010-03-26 17:11:30
Thanks for help…
Did you ever get this fixed?
Unfortunatly no.
