MP4 H.264 has no sound
i have converted my files to mp4 H264 format cos it has better quality but when i play t using your WD TV(generation 1, firmware 1.03) there is no sound and also my display also started to wave after updating to 1.03 firmware…
any suggestion to solve this problem?
thank you
This forum is for the WDTV ‘Live’.
The WDTV 1st Gen player forum is here:
http://community.wdc.com/t5/WD-TV-HD/bd-p/tv_hd
There should be WDTV owners there who can better advise you.  The ‘Live’ uses a completely different firmware, 1.01.17 (which, incidentally, has an audio lag bug on MP4 files, not present on WDTV 1st Gen players).
Try posting more information about what software you used to convert your files, what audio codec you selected (H264 is the video codec) and also what the files were before you encoded them (container, codecs, etc).  It could be an encoding issue, not a hardware one.
What is the ETA on this bug fix… seems like a major issue since MP4 is a popular container
