MP4 Audio Sync Issue with BluRay 720P rip
I have converted all of my DVDs to MP4 using the latest Handbrake, using the high profile setting and constant quality of 18.  For the most part they all work great.
However, I just started ripping my BluRay collection, using Handbrake 0.9.5 (2011010300), again using the default High Profile settings, adjusting the picture width to 1280 (basically making the videos 720p).  However, when I play the videos on the WD TV LIVE+, the audio is about 1/4 second faster than the video.  This discprepency is consistent for all of the BluRays I’ve ripped.  There does not appear to be any change in the offset for the duration of the movies.  There is no audio sync issue if I play them on my PC (Win7 x64) using either Media Player, VLC or QuickTime.  My iPad (change extension to m4v) and Blackberry also have no issues.  I’ve tried network and local USB and I get the exact same results.  I have updated to the latest firmware (not sure what I had before) and it has the same issues.
Here is a media info snippet for one of the videos in question:
General
Complete name                    : G:\CD-DVD\Some Video.mp4
Format                           : MPEG-4
Format profile                   : Base Media / Version 2
Codec ID                         : mp42
File size                        : 3.04 GiB
Duration                         : 2h 20mn
Overall bit rate                 : 3 108 Kbps
Encoded date                     : UTC 2011-03-29 19:15:16
Tagged date                      : UTC 2011-03-29 21:54:01
Writing application              : HandBrake 0.9.5 2011010300
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L3.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 4 frames
Format settings, GOP             : M=4, N=42
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 2h 20mn
Bit rate mode                    : Variable
Bit rate                         : 2 303 Kbps
Width                            : 1 280 pixels
Height                           : 528 pixels
Display aspect ratio             : 2.35:1
Frame rate mode                  : Variable
Frame rate                       : 23.976 fps
Minimum frame rate               : 23.974 fps
Maximum frame rate               : 23.981 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.142
Stream size                      : 2.25 GiB (74%)
Writing library                  : x264 core 112
Encoding settings                : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format profile                   : LC
Codec ID                         : 40
Duration                         : 2h 20mn
Bit rate                         : 160 Kbps
Maximum bit rate                 : 243 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Sampling rate                    : 48.0 KHz
Compression mode                 : Lossy
Stream size                      : 160 MiB (5%)
Tagged date                      : UTC 2011-03-29 21:54:00
Audio #2
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : ac-3
Duration                         : 2h 20mn
Bit rate mode                    : Constant
Bit rate                         : 640 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Stream size                      : 641 MiB (21%)
I’m only 20 rips into this and I would be interested to know if this is expected behavior, or if there are some HandBrake settings I need to adjust.
Thanks for any help.
B
Have you tried changing the audio and video codecs?
