mp4 - audio no video. Help?
Hi all, I have a movie rip on a media server which i can play fine from xbmc, but when i run it to my wd TV Live i get a blank screen with audio. here is the video information:
General
Complete name                            : C:\Users\Joseph\Desktop\Argo.mp4
Format                                   : MPEG-4
Format profile                           : Base Media
Codec ID                                 : isom
File size                                : 1.65 GiB
Duration                                 : 2h 0mn
Overall bit rate mode                    : Variable
Overall bit rate                         : 1 961 Kbps
Encoded date                             : UTC 2013-01-31 12:00:31
Tagged date                              : UTC 2013-01-31 12:00:31
Writing application                      : Yamb 2.1.0.0 [http://yamb.unite-video.com]
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High 10@L5.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 11 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 2h 0mn
Bit rate                                 : 1 862 Kbps
Maximum bit rate                         : 11.4 Mbps
Width                                    : 1 920 pixels
Height                                   : 800 pixels
Display aspect ratio                     : 2.40:1
Frame rate mode                          : Constant
Frame rate                               : 23.976 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 10 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.051
Stream size                              : 1.56 GiB (95%)
Title                                    : 2012.1080p.bluray.x264-sparks.mkv.264#trackID=1
Writing library                          : x264 core 129 r2245 bc13772
Encoding settings                        : cabac=1 / ref=12 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=1862 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=81 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Encoded date                             : UTC 2013-01-31 19:46:26
Tagged date                              : UTC 2013-01-31 12:00:36
can anyone explain why i get no video?
The LIVE does not support 10bit. HP@L4.1 is max as mentioned n the manual.
How Can I correct this issue with the file?  I am not well informed as to this type of information.  Is there some form of conversion i can do?
You can recode it with Handbrake which will take time, increase filesize and lose quality. IOW, better user other files, AFAIK no current standalone player supports 10bit.
