Moving abroad... Voltage question for WD My Book for Mac 2TB USB 3.0 Desktop External Hard Drive
I have a hard drive model: WD My Book for Mac 2TB USB 3.0 Desktop External Hard Drive Model WDBYCC0020HBK-NESN. This was purchased in Canada but I am moving to the UK and need to know if this drive’s voltage will be compatible with a UK power supply? Should I just buy a converter for the American plug or is there some place I can buy a UK plug power supply for this unit? If I need to get a new power supply what should I look for in a new power supply cord?
Thanks!
Hello and welcome to the WD Community.
This unit works with AC Input Voltage 100-240 VAC I believe that just need to get the adapter to connect your power adapter.
Thank you so much for your answer :slight_smile:
