HomerJ wrote:
Just to clarify , when looking at movie list, clicking info on movie brings up an options page for you to view info, rescan info, view youtube trailer etc. Yes for me it is distorted also, the xml for this page is option_menu_page.xml, this appears for me in the the top left corner not the top right, probably theme related.
applying this edit:
<image image=“@@option_menu_thumbnail” default_image=“@@option_menu_default_thumbnail” x=“70” y=“47” w=“138” h=“138” align=“right” scale=“100” scale_type=“pan”/>
will correct it, note that the size of the image is w=138 and h=138, this will need to be tweaked also.
Clicking view info on this pages options menu gives the meta data, I think the xml to edit in this case is metadata_view_info.xml , I havent had a chance yet to verify but will when I get time.
I copied the option_menu_page.xml from OSD to JSMOD AeonDark and made the edit you mentioned above.
I also copied over metadata_view_info.xml. Looks like the spot would be:
<image image=“@@movie_metadata_thumbnail_bg” x=“70” y=“49” w=“139” h=“196” align=“hcenter” scale_type=“fixratio” scale=“100”/>
<image image=“@@movie_metadata_thumbnail” x=“70” y=“49” w=“139” h=“196” align=“hcenter” scale_type=“fixratio” scale=“100”/>
Not sure why its repeated twice. I have not played with it yet as the little one is watching TV, which means I have not tested the option_menu_page.xml edit yet either. Thanks for sorting that one out. once they are all edited, Ill update the download.
Sicne you seem to be a great tracker HomerJ, maybe you can find another one for us. If you switch to preview view and highlight a movie, you will notice that the preview movie on the right is half cut off because with Joeys background with the 2 black boxes, the preview window had to be moved to the left in order to be centered. However I am unable to locate where to actually move the preview video to the left. Thanks
