Apricorn Padlock DT 3.0TB USB3 disk is now mountable on 1.04.4 firmware, it was not possible before this version.
the 3TB drive was formated on centos 6.5 with /dev/sdb1 as linux fs and init with ext4 fs type, it shows 3TB capacity.
moving the disk to EX2 with 1.04.4 firemware and it was able to be auto mounted, but still it only show 2TB in size.
See following detail from “demsg” and “df -h” output.
usb 4-1: new SuperSpeed USB device number 9 using xhci_hcd
scsi3 : usb-storage 4-1:1.0
scsi 3:0:0:0: Direct-Access Apricorn Padlock DT 3.0 0120 PQ: 0 ANSI: 6
sd 3:0:0:0: [sdc] Very big device. Trying to use READ CAPACITY(16).
sd 3:0:0:0: [sdc] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
sd 3:0:0:0: [sdc] 4096-byte physical blocks
xhci_hcd 0000:00:00.0: WARN: Stalled endpoint
sd 3:0:0:0: Attached scsi generic sg2 type 0
sd 3:0:0:0: [sdc] Write Protect is off
sd 3:0:0:0: [sdc] Mode Sense: 2b 00 10 08
sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
sdc: sdc1
sd 3:0:0:0: [sdc] Attached SCSI disk
EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
~ # df -h |grep c1
/dev/sdc1 2.0T 198.0M 1.9T 0% /mnt/USB/USB1_c1
5. Question, is this just display error on size ? Can I really write to sdc1 upto 3TB safely ?
