I have 100GB memory of 1 & 1 as smart drive.
Can I put in the WD MyCloud this by issuing the mount command?
If so, how?
Thanks in advance …
If so, how?
Thanks in advance …
WDMyCloud does not support davfs2 officially. You’ll need to manually install in v3 firmwares and build manually patch with 64k page size memory for v4 firmwares. Modifications will void warranty.
