Hi guys,
my WD LIve Hub TV refuses to play this file :
General Unique ID : 197181690059567248849422363487304584966 (0x9457CFE836E215BE94A041F3F7868F06)
Complete name : X:\Cleopatra.mkv
Format : Matroska
Format version : Version 2
File size : 19.9 GiB
Duration : 4h 11mn
Overall bit rate : 11.3 Mbps
Movie name : Cleopatra (1963)
Encoded date : UTC 2012-07-18 14:13:41
Writing application : mkvmerge v5.7.0 (‘The Whirlwind’) built on Jul 8 2012 20:08:51
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Attachment : Yes / Yes / Yes
Video ID : 1
Format : AVC
Format profile : High 10@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 4h 11mn
Bit rate : 10.5 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.210
Stream size : 18.3 GiB (92%)
Writing library : x264 core
Language : English
Default : Yes
Forced : No
Audio ID : 2
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 4h 11mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 1.12 GiB (6%)
Language : English
Default : Yes
Forced : No
Text ID : 3
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain
Text Language : Dutch
Default : Yes
Forced : No
I get a warning that I have to consult the manual, because the format is not supported. Can anyone explain me what is wrong with this mkv-file and what makes it not playable ?
kind regards.
