After a reboot the porgram worked…
I hope this is what you need??
General
UniqueID/String : 209242326295608992114623504602044565053 (0x9D6A9B2EE9E6561199103B403F38063D)
CompleteName : E:\Torrents\The Nightmare Before Christmas.mkv
Format : Matroska
Format_Version : Version 2
FileSize/String : 4.37 GiB
Duration/String : 1h 16mn
OverallBitRate/String : 8 167 Kbps
Movie : The Nightmare Before Christmas (1993)
Encoded_Date : UTC 2010-06-11 16:03:17
Encoded_Application : mkvmerge v3.2.0 (‘Beginnings’) built on Feb 12 2010 16:46:17
Encoded_Library/String : libebml v0.7.9 + libmatroska v0.8.1
Video
ID/String : 1
Format : AVC
Format_Profile : High@L4.1
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 4 frames
CodecID : V_MPEG4/ISO/AVC
BitRate/String : 6 655 Kbps
Width/String : 1 800 pixels
Height/String : 1 080 pixels
DisplayAspectRatio/String : 1.667
FrameRate_Mode/String : Constant
FrameRate/String : 23.976 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
Bits-(Pixel*Frame) : 0.143
StreamSize/String : 3.48 GiB (80%)
Title : x264 @ 6655kbps
Encoded_Library/String : x264 core 65 r999 cc51047
Encoded_Library_Settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=2 / deadzone=8,6 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=6655 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=40000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.10
Language/String : English
Default/String : Yes
Forced/String : No
Audio
ID/String : 2
Format : DTS
Format/Info : Digital Theater Systems
Format_Profile : ES
Format_Settings_Mode : 16
Format_Settings_Endianness : Big
CodecID : A_DTS
BitRate_Mode/String : Constant
BitRate/String : 1 510 Kbps
Channel(s)/String : 7 channels / 6 channels
ChannelPositions : Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
SamplingRate/String : 48.0 KHz
BitDepth/String : 24 bits
Compression_Mode/String : Lossy
StreamSize/String : 828 MiB (18%)
Title : DTS-ES 6.1 @ 1.5mbit
Forced/String : No
Text #1
ID/String : 3
Format : UTF-8
CodecID : S_TEXT/UTF8
CodecID/Info : UTF-8 Plain Text
Language/String : Spanish
Forced/String : No
Text #2
ID/String : 4
Format : **bleep**
CodecID : S_TEXT/**bleep**
CodecID/Info : Advanced Sub Station Alpha
Compression_Mode/String : Lossless
Default/String : No
Forced/String : No
Text #3
ID/String : 5
Format : **bleep**
Language/String : Danish
Default/String : No
Forced/String : No
Text #4
ID/String : 6
Format : **bleep**
Language/String : Dutch
Default/String : No
Forced/String : No
Text #5
ID/String : 7
Format : **bleep**
Language/String : French
Default/String : No
Forced/String : No
Text #6
ID/String : 8
Format : **bleep**
Language/String : Portuguese
Default/String : No
Forced/String : No
Text #7
ID/String : 9
Format : **bleep**
Language/String : Swedish
Default/String : No
Forced/String : No
