I have install the latest firmware but still i can’t play dual audio mkv files on my Hub, will somebody help me?
Hi Chame.
What do you mean by dual audio? If you meant “audio track” then press the audio button on the remote to change it.
Cheer
i have some chinese movie in mkv file and there audio are dual ( meaning that it switch to cantonese or mandarin) but when i switch it to mandarin the screen went black all you can hear is the audio. when i play in cantonese version and press fast forward a message will show in the screen say “Trick Mode is not Supported”. Pls any one help me
Bad encode. You’ll have to re-encode the file properly to get it to play properly.
how?
