Hi all,
So I made a mistake in editing my sshd_config whilst logged in over ssh and broke sshd. I’ve succeeded in extracting the drive and am using a USB caddy and fuse-ext2/MacFUSE in order to mount the drive under OS X 10.6.8. The drive contains four partitions:
disk1s1 - the root partition (2GB ext3 journalled)
disk1s2 - the data partition (~960GB unknown format)
disk1s3 - /var (~280MB - ext3 journalled)
disk1s4 - don’t know (1GB unknown format)
Here’s what I’ve been trying to do. I can mount the root partition read-write and edit /etc/sshd_config (in fact I saved a backup of it so I’m deleting the modified file and renaming the backup), but when I put the drive back into the MBWE and boot up, I find that ssh is still not operative (it’s still not listening on port 22 - my config modifications didn’t change the port).
Here’s where it gets weird. If I dismantle it all once more and plug the drive back into the USB caddy, the sshd config files in /etc have gone back to exactly how the were before the manual deletion and rename! It’s as though the drive has some sort of mirror backup that it automatically restores on bootup. I’ve tried editing other files and get the exact same behaviour - my edits just disappear!
So then, is anyone familiar with this problem or can suggest a way around it? I’m all out of ideas now. I am using MyBookClone from highlevelbits.free.fr but unfortunately the sshd config error was backed up to the backup drive before I realised the mistake. Also I don’t run Windows so cannot use his MyBookRescue software either.
I’m open to anything at this point - especially an explanation for this weird ‘backing out my changes’ behaviour.
Many thanks,
Ian
