I just bought one of these and it’s really quite nice. It came with 2 WD 1TB Green drives. I have a few questions about the unit…
Can the drives be set so that they appear as 2 different drives ( that is no RAID)?
Is it possible to replace both drives by say two 2TB WD Green drives and have the unit work or is there something preinstalled on one of the two drives?
Each time I connect to the web page I have to enter the admin password. Is there something preventing browsers from storing it?
Is HFS+ supported as a USB drive format?
Thank’s…philip
Edit: 1.By using JBOD you get two different drives so that appears to be the unRaid option.
According to reviews you can simply replace the drives with 2 WD Green drives. See http://www.desktopreview.com/default.asp?newsID=708&Review=Western+Digital+My+Book+World+Edition+II
was a browser issue on my part.
HFS+ is supported.
