MBL is dead, please help!
hi, i have no clue what happened with my MBL.
all was working fine until yesterday, when trying to access my videos, i can’t reach my MBL. so i went downstairs to have a look, and i saw that the light on my MBL was blinking white.
i’ve powered it down, hit the reset button, still the same.
what goes up? has my MBL suddenly just died?
thanks!
“blinking” white, unfortunately, isn’t defined in the manual.
Solid white means the FW is being updated.
Blinking YELLOW means that there’s a hardware issue such as thermal overload or a network failure.
well, looks like white to me, but i won’t argue :slight_smile:
hardware issue? that hardware is not a year old.
network issue? why would only my MBL have network issue, when all other devices (ipad, iphone, android tablet, android phone, pc, ps3, laptop) are ok?
so, what’s the next step for me to identify the problem?
thanks!
Cause the cable could be bad, not getting an IP, not in all the way at either end, bad port on router
If you believe all is ok, then open case and if dead and not a year old, you might also be able to get a replacement.
Well, the cable was not ok.
I checked it and noticed that it does not click in place. I’ve pushed it and my mbl is working.
I’ll get a new cable as soon as possible.
Thanks!
