I have newly purchased a 3TB Gen2 MyCloud with firmware 2.21.126.
I would like to manually upgrade to the latest firmware but I have difficulty following these instructions (on Software and Firmware Downloads | WD Support), having specified the Gen2 firmware version:
"Updating the firmware on your My Cloud
_Download the firmware to your desktop_.
_Unzip the file and you will find the actual firmware in this format: My_Cloud_GLCR_2.xx.xxx.zip._
_Save this to your desktop_ "
But the downloaded file is called My_Cloud_GLCR_2.30.181.bin and I don’t know how to unzip a .bin file. Using Win 7.
I’ve not been able to find a similar question on the forum so I must assume I’m being really dumb while everyone else knows the answer.
Well who’d have thought the “official” instructions could be incorrect…
Installed without a murmur from the .bin file directly - no prior extraction necessary. Just a pity they haven’t put the “Shutdown” button back in this version. So now I’m off to get plink or putty.
Thanks again, cpt_paranoia. Your input on this forum is much appreciated.
Edit: Oh, wait, WD QuickView is the solution for my environment.
