Hi there, I need some help. I’ve searched all over the web and cant find a solution to this, lots of attempts but so far nothing has worked.
I have an “Early 2013” MacBook Pro Retina running OSX El Capitan 10.11.6. I am trying to access my EX4 through the “Finder” on my Mac and it will not connect. I can access it through the WD MyCloud App, but I need to use finder so I can upload some more files.
Is there a fix for this, any ideas? It seems like this is a problem with El Capitan, and WD’s suggestion was to upgrade to El Cap ver 10.11.2, which is several updates ago. I figured by now they would have this figured out, but I can’t find the solution. This is massively frustrating.
Any ideas? Thanks…
